StewartDrake Posted November 13, 2020 Share Posted November 13, 2020 Hey, So Currently I am using the HX Stomp as the Brain of my rig. Which means I would like the tempo that I have for the preset to be sent to my digital delay which is a dd-200. Why I want to do this is because space is limited and I cannot fit another thing on my board, and it's super complicated to time up the repeat time between the 2 devices. My HX Stomp settings are as Followed: Midi Base Channel: 1 Midi Thru: On Rx Midi Clock: Off Tx Midi Clock: On Tempo Selection: Preset BPM: 120 USB Midi: Off Midi PC Rx: Off Midi PC Tx: Midi My Boss DD200 Settings are as Followed: Midi Receive Channel: 1 Midi Transmit Signal: off PC In: On PC Out: Off CC in: ON CC Out: Off SYNC: Auto Realtime Source: Midi Can someone tell me what I am doing wrong? Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 13, 2020 Share Posted November 13, 2020 How do you have the two connected? The DD200 takes the mini TRS connection, right? What adapter are you using? Quote Link to comment Share on other sites More sharing options...
StewartDrake Posted November 13, 2020 Author Share Posted November 13, 2020 I’m using a Mini TRS to 5 pin DIN cable to connect them Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 13, 2020 Share Posted November 13, 2020 One thing I just noticed in your original post... MIDI Thru on the Stomp should be turned off. Quote Link to comment Share on other sites More sharing options...
