hosukgun 0 Posted November 20, 2020 Hi i use amplifi75 I Connected amplifi75 to the computer And turn on neural dsp Then, the sound amplifi75 and the neural dsp sound overlap. How can i turn off amplifi75 sound?? Thank you!! IMG_3452.MP4 Quote Share this post Link to post Share on other sites
RileyVallance19 5 Posted November 22, 2020 Hi Hosukgun, What I have done with my Amplifi to use with my other effects processor board is replace the 1A tone with a custom tone I created called FRFR (Full Range Frequency Response). In the tone I have turned off all effects and amps except reverb (which is on but set to 0 by default). This gives me the ability to use all my pedal board's effects with no Amplifi tones interfering with the sound, and I can simplify reverb simply by turning the knob on my amp to the level ideal to the situation I'm in. I used this setup when I was a guitarist in the orchestra for Mamma Mia in January and February this year and it worked flawlessly. I believe a similar setup may work for you, however I am not sure what the latency for the Neural DSP plugin will be like with the Amplifi. I am interested to see how it works out for you because I have been tossing up getting some plugins for a while, to use with my line 6 gear. Hopefully this helps for you! Riley. Quote Share this post Link to post Share on other sites
