TimWalker7620 Posted November 24, 2020 Share Posted November 24, 2020 Hey all, looking for some guidance as to how to fix this issue assuming my HX stomp bricked. I just recently updated both my Helix Rack and HX Stomp to the new 3.0 firmware using Mac OS 10.14 with no issues to the Helix Rack but now after the initial boot screen on the HX stomp, the screen goes black and shows pixelated blue squares where dialog boxes would be on the screen. It still connects to HX Edit and I'm able to navigate that way but the pedal display is not usable. I've tried to factory reset a few times but nothing so far has fixed this issue. Anyone else experience/solve this issue before? Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 24, 2020 Share Posted November 24, 2020 5 hours ago, metalhead77479 said: Hey all, looking for some guidance as to how to fix this issue assuming my HX stomp bricked. I just recently updated both my Helix Rack and HX Stomp to the new 3.0 firmware using Mac OS 10.14 with no issues to the Helix Rack but now after the initial boot screen on the HX stomp, the screen goes black and shows pixelated blue squares where dialog boxes would be on the screen. It still connects to HX Edit and I'm able to navigate that way but the pedal display is not usable. I've tried to factory reset a few times but nothing so far has fixed this issue. Anyone else experience/solve this issue before? Hi, That sounds very strange, not something that’s been reported previously AFAIK. You said that you tried a factory reset with no success, but as you note that it can still connect over USB so that it shows in HX Edit, I would possibly be tempted to re-flash the firmware again to see if it clears the issue on the screen. Basically, you have nothing to lose so give it a shot. Hope this helps/makes sense Quote Link to comment Share on other sites More sharing options...
TimWalker7620 Posted November 25, 2020 Author Share Posted November 25, 2020 It boots with the normal screen Then loads with this as the UI Will try to re-flash and report back Quote Link to comment Share on other sites More sharing options...
TimWalker7620 Posted November 25, 2020 Author Share Posted November 25, 2020 Update: SUCCESS! Initially I updated through HX Edit and that's where the buggy install occurred. Just tried to reinstall using the L6 Updater instead and glad to report a successful install without the UI glitch. 1 Quote Link to comment Share on other sites More sharing options...
wardadeuce Posted February 28, 2021 Share Posted February 28, 2021 I am having the same issue that you were metalhead, except that the Line 6 updater is not able to connect to the hx stomp no matter what I do. I've restarted my computer, installed the driver necessary, and even tried factory resetting the device. Nothing has worked. It is quite frustrating, I hope someone at line 6 can help with this soon. Quote Link to comment Share on other sites More sharing options...
lepilepi Posted March 11, 2021 Share Posted March 11, 2021 First, I had similar screen issues after I updated to 3.01 via HX Edit, but then I used the Line6 Updater to flash the same firmware again and it fixed the problem successfully. OSX 11.2.1 Line6 Updater 1.19 HX stomp Firmware 3.01 Quote Link to comment Share on other sites More sharing options...
Rad_Pug Posted October 22, 2021 Share Posted October 22, 2021 I am having this exact issue. When I try the updater it starts and says error. Quote Link to comment Share on other sites More sharing options...
JelleVC Posted May 30, 2023 Share Posted May 30, 2023 I have the same problem. My HX Stomp was still running the 2.92 update. I connected this wit the HX Editor, tried to update. I got an error and now the screen is flashing like described above. I tried to install the Lin6 Updater, but miy macbook (macOS Big Sur) won't open it (says it kan scan the program, I need to contact Line6). Any help here? Quote Link to comment Share on other sites More sharing options...
dasmoothest Posted March 18, 2024 Share Posted March 18, 2024 I'm a Worship Director at a church and we have 3 of these and for some reason, one of them was working totally fine and then the screen went black and we can't get it back. Did the latest frimware update and the update via HX Edit as well and neither of them worked. This really is inconvenient because we are in the middle of preparing for our HUGE Easter production! Has anyone had success with solving this issue? IMG_4161.heic Quote Link to comment Share on other sites More sharing options...
rekrdskratcher Posted May 14, 2024 Share Posted May 14, 2024 (edited) On 3/18/2024 at 11:43 AM, dasmoothest said: I'm a Worship Director at a church and we have 3 of these and for some reason, one of them was working totally fine and then the screen went black and we can't get it back. Did the latest frimware update and the update via HX Edit as well and neither of them worked. This really is inconvenient because we are in the middle of preparing for our HUGE Easter production! Has anyone had success with solving this issue? IMG_4161.heic 987.37 kB · 2 downloads Same thing JUST happened with mine - display is FAINTLY there, full reset doesn't seem to fix it either... I had to take a picture with the lights off and in night mode on my phone for it to even show, otherwise it looks basically black Edited May 14, 2024 by rekrdskratcher added pictures Quote Link to comment Share on other sites More sharing options...
rekrdskratcher Posted June 20, 2024 Share Posted June 20, 2024 On 5/13/2024 at 10:32 PM, rekrdskratcher said: Same thing JUST happened with mine - display is FAINTLY there, full reset doesn't seem to fix it either... I had to take a picture with the lights off and in night mode on my phone for it to even show, otherwise it looks basically black Line 6 Support ended up replacing an MCU board and encoder under warranty, for those who come to this post in the future. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 20, 2024 Share Posted June 20, 2024 On 6/20/2024 at 8:32 PM, rekrdskratcher said: Line 6 Support ended up replacing an MCU board and encoder under warranty, for those who come to this post in the future. Thanks for the update on your situation - far too many people don’t bother to advise other users of the final outcome. Quote Link to comment Share on other sites More sharing options...
