Arek777 Posted November 26, 2020 Share Posted November 26, 2020 I have Powercab 112 The LED ring on the back changes color as different speaker mods are selected. What color means what speaker? Which color is for (FRFR )flat? Manual lists the models, but does not tell the corelation. Is the speaker selection passed on to XLR OUT? ie. FOH or do I have to use mic in front of the cab to hear the emulated tone through FOH? Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 26, 2020 Share Posted November 26, 2020 The LED colors don't really mean anything. Those are just the different colors associated with each speaker model. You can choose a different color for the preset if you want. Quote Link to comment Share on other sites More sharing options...
Arek777 Posted November 26, 2020 Author Share Posted November 26, 2020 (edited) 1 hour ago, phil_m said: The LED colors don't really mean anything. Those are just the different colors associated with each speaker model. You can choose a different color for the preset if you want... ...and that is my question: What LES color corresponds with what speaker model? If the light is green that means which speaker model is active? I think I found the answer......on the back......and in manual. Edited November 26, 2020 by Arek777 added photo Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 26, 2020 Share Posted November 26, 2020 30 minutes ago, Arek777 said: ...and that is my question: What LES color corresponds with what speaker model? If the light is green that means which speaker model is active? I think I found the answer......on the back......and in manual. Yeah, they do correspond to those colors, although the Powercab Plus has had additional speaker models added since the time the original release. If you scroll through the available speaker models in speaker mode, you’ll see the LED change color. The color that comes up as you select each model is the default color associated with that speaker. Quote Link to comment Share on other sites More sharing options...
