Michael_E Posted December 2, 2020 Share Posted December 2, 2020 OMG I feel like I am just coming up to speed in the age of the combustion engine..... I am reading the manal.. My goal is to have a patch from a footswitch, go to to a specific amp. I have one clean and one dirty. I also have a Source Audio programmable EQ2. I currently have that in line after my outputs to the amps [should I put it back to the front end, receiving my guitar signal and splitting to both inputs of the HX unit?]. The EQ2 has parallel outputs, meaning that I can send different eq values to each amp. I have this hooked up via midi to the HX unit but I don't know how to access this yet as I would like to have specific presets from the EQ, go along a patch in to a specific amp. I have two different fuzzes in each loop. Is there a tutorial that will walk me through these most basic of tasks? Good grief I feel dumb. Thanks Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 3, 2020 Share Posted December 3, 2020 I'm not quite sure what you're after when you say: 14 hours ago, Michael_E said: My goal is to have a patch from a footswitch, go to to a specific amp. I have one clean and one dirty. If I've interpreted it correctly, attached is an example preset showing how it's done in a single path. Path A (reverb will be on the L/Mono Out, Path B (delay) will be on the RIGHT Out. Pay attention to the panning in the split and mix blocks. MichaelE.hlx Quote Link to comment Share on other sites More sharing options...
Michael_E Posted December 6, 2020 Author Share Posted December 6, 2020 On 12/2/2020 at 4:45 PM, rd2rk said: I'm not quite sure what you're after when you say: If I've interpreted it correctly, attached is an example preset showing how it's done in a single path. Path A (reverb will be on the L/Mono Out, Path B (delay) will be on the RIGHT Out. Pay attention to the panning in the split and mix blocks. MichaelE.hlx 5.35 kB · 0 downloads Thank you! I have been able to figure out the panning thankfully. This will help me to refine the path. Much appreciated. Quote Link to comment Share on other sites More sharing options...
