raimdal Posted December 2, 2020 Share Posted December 2, 2020 Hi, in my town a guy is solding a pod hd500 with broken usb. I have a usb to midi cable. Can I use line6 software by this simple solution, can midi to USB cable replace the usb connection? So I can download pathces and recording on my software playing on backing tracks? Thanks a lot Quote Link to comment Share on other sites More sharing options...
JohannDaart Posted December 2, 2020 Share Posted December 2, 2020 MIDI to USB cable provides ability to send (only) MIDI info to your PC. HD's USB to USB connection sends a lot more than just MIDI. So NO, it won't work the way you think it will. If you don't have soldering skills or a friend that could help with it, so you could repair it by soldering in new USB connector, then wait a bit for a fully functional HD500 unit on used market. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted December 3, 2020 Share Posted December 3, 2020 It better be real cheap if the USB port is broken. 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 3, 2020 Share Posted December 3, 2020 15 hours ago, JohannDaart said: ..... If you don't have soldering skills or a friend that could help with it, so you could repair it by soldering in new USB connector, ..... Be aware that in many (most?) cases repairing a broken USB connection on a POD HD500 also requires replacing an internal circuit board. Fixing the USB port itself usually won’t fix the problem. 2 Quote Link to comment Share on other sites More sharing options...
JohannDaart Posted December 3, 2020 Share Posted December 3, 2020 6 hours ago, silverhead said: repairing a broken USB connection on a POD HD500 also requires replacing an internal circuit board If that's the case, then yeah, another reason to stay away from broken units. Quote Link to comment Share on other sites More sharing options...
raimdal Posted December 6, 2020 Author Share Posted December 6, 2020 Ok, thank you all! Quote Link to comment Share on other sites More sharing options...
