Smj7 Posted December 9, 2020 Share Posted December 9, 2020 Hey folks, I'm running Pro Tools 11 with Windows 10. I have a Lynx Aurora 16 digital I/O (AES output) and the HX Stomp (USB output). Here's my issue: When I plug the HX stomp's USB into my computer, it sends audio to the computer fine. The computer sends audio back through the HX stomp fine. What I want though, Is for the audio to be routed through the Lynx Aurora 16 for monitoring. When I select the "interface" option on a track to select the I/O, only my Lynx Aurora shows up... not the HX stomp. Obviously, Pro Tools is seeing Stomp as the audio gets to the track ok.... but I don't even have it selected in the interface. I therefore can't send direct sounds simultaneously. Am I missing something or is this a limitation of this version of Pro Tools? Sean Meredith-Jones www.seanmeredithjones.com Quote Link to comment Share on other sites More sharing options...
lou-kash Posted December 9, 2020 Share Posted December 9, 2020 23 minutes ago, Smj7 said: Am I missing something Apparently Windows – unlike MacOS – cannot create "aggregate audio devices" out of the box: https://duckduckgo.com/?q=aggregate+audio+device+windows Which is what you likely need if you want to use both devices simultaneously. Quote Link to comment Share on other sites More sharing options...
Smj7 Posted December 9, 2020 Author Share Posted December 9, 2020 51 minutes ago, lou-kash said: Apparently Windows – unlike MacOS – cannot create "aggregate audio devices" out of the box: https://duckduckgo.com/?q=aggregate+audio+device+windows Which is what you likely need if you want to use both devices simultaneously. I figured that that might be the case between limitations of one of the devices being used (Stomp, Computer, Aurora, Pro Tools). I will indeed look into it. I didn't know the term to look for so that's very helpful! Btw, is there a quick way to mute the USB output in the stomp so I can at least use it as a remote until I figure this out? Sean Meredith-Jones www.seanmeredithjones.com Quote Link to comment Share on other sites More sharing options...
