hodd Posted December 11, 2020 Share Posted December 11, 2020 I opened a support case with Line 6 on this, but I just wanted to see if anyone else is having an issue updating to 3.0 from either HX Edit or the Line 6 Updater? I've tried everything and what happens in HX Edit is the update gets to 12% (sometimes 14 %) and just hangs there. I've left it running for hours and it never goes past this. On the Stomp the animated "Updating..." just freezes. In the Line 6 Updater it gets to to the "m" in Updating firmware and freezes there. All I can do is then revert back to 2.92 (this can take a few attempts but I can get it back so it's at least not bricked) Support has asked me to take it in to get serviced, but the whole COVID thing is not good where I am, and I'd prefer to not have to do this yet. I've tried changing USB cables. I've tried on 2 different PCs, and a Mac. I feel like it can't be a hardware issue if I'm able to update previous firmwares with no problem. If anyone has something I could try or experienced a similar issue, I'm open to suggestions! Thanks in advance. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted December 11, 2020 Share Posted December 11, 2020 Did you try an offline update, using the Flash Memory files provided in the download section? Quote Link to comment Share on other sites More sharing options...
hodd Posted December 11, 2020 Author Share Posted December 11, 2020 10 minutes ago, SaschaFranck said: Did you try an offline update, using the Flash Memory files provided in the download section? Yup, I've tried with downloading the files first...still same outcome on all 3 systems. Also, 3.00 and 3.01 give me the exact same results when updating. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted December 11, 2020 Share Posted December 11, 2020 So you did a factory reset boot as well? Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted December 11, 2020 Share Posted December 11, 2020 https://helixhelp.com/manuals/helix/reset-options/ Quote Link to comment Share on other sites More sharing options...
hodd Posted December 11, 2020 Author Share Posted December 11, 2020 13 minutes ago, SaschaFranck said: https://helixhelp.com/manuals/helix/reset-options/ Yes sir, did the full reset using the methods you linked. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted December 11, 2020 Share Posted December 11, 2020 This is pretty weird, given that you can revert to previous firmware versions. I'd probably contact the Line 6 support, because apart from the usual update methods (a full reset along with an offline update being the most crucial ones), there's not much other recommendations you may find round these parts. Well ok, maybe you could still try to revert to a previous version, clean all your presets and IRs, then do a factory reset before attempting to update. 1 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted December 11, 2020 Share Posted December 11, 2020 First thing I would try is unplugging any unnecessary peripherals and rebooting my PC and trying another USB cable and/or USB port. You say you downloaded the flash file so that to me indicates that you have already tried using the Updater manually. Btw, make sure you don't have HX Edit and the Updater up at the same time. Have you also uninstalled and reinstalled HX Edit 3.0 with all checkboxes checked? Next thing I would attempt is when the device stops updating, exit HX Edit and restart the update process or if that does not work unplug/replug the USB cable and restart. Note: this is contrary to the clearly printed instructions printed in red on the install screen and has the potential to either leave the PC unable to "see" your device or leave your device with a scary error message and unable to start properly. It will not however be "bricked". You can almost be guaranteed that short of an actual and unlikely hardware problem this will not be the case. If all else fails open a ticket with Line6 and they can walk you through the update(or you can just start the process by contacting them and potentially avoid dire looking error messages). 1 Quote Link to comment Share on other sites More sharing options...
Joaotex97 Posted May 31, 2021 Share Posted May 31, 2021 I can't do the update either, I think about selling my HX Stomp because Line 6 in Brazil is very difficult for anything Quote Link to comment Share on other sites More sharing options...
hodd Posted June 1, 2021 Author Share Posted June 1, 2021 1 hour ago, Joaotex97 said: I can't do the update either, I think about selling my HX Stomp because Line 6 in Brazil is very difficult for anything Mine has been at the Yamaha repair center since January to get the main board replaced. Once I get it back I'll be selling mine too. Through the whole process Line6 didn't give a crap about me and handed it off to warranty. I'm 100% done with all their products. Never again. Quote Link to comment Share on other sites More sharing options...
marcosjr340 Posted October 18, 2021 Share Posted October 18, 2021 On 12/10/2020 at 11:16 PM, hodd said: opened a support case with Line 6 on this, but I just wanted to see if anyone else is having an issue updating to 3.0 from either HX Edit or the Line 6 Updater? I've tried everything and what happens in HX Edit is the update gets to 12% (sometimes 14 %) and just hangs there. I've left it running for hours and it never goes past this. On the Stomp the animated "Updating..." just freezes. In the Line 6 Updater it gets to to the "m" in Updating firmware and freezes there. All I can do is then revert back to 2.92 (this can take a few attempts but I can get it back so it's at least not bricked) Support has asked me to take it in to get serviced, but the whole COVID thing is not good where I am, and I'd prefer to not have to do this yet. I've tried changing USB cables. I've tried on 2 different PCs, and a Mac. I feel like it can't be a hardware issue if I'm able to update previous firmwares with no problem. If anyone has something I could try or experienced a similar issue, I'm open to suggestions! I have the same problem, did you get any response from support, are there specific devices with this problem? Quote Link to comment Share on other sites More sharing options...
hodd Posted October 19, 2021 Author Share Posted October 19, 2021 16 hours ago, marcosjr340 said: I have the same problem, did you get any response from support, are there specific devices with this problem? I opened a case with Line 6 and created a return with my local repair shop. I sent it to them in late January of this year, and didn't get it back from repair until July. So good luck with your RMA :) My Stomp has been in the box ever since. In that time I bought a Quad Cortex, and never looked back. 1 Quote Link to comment Share on other sites More sharing options...
marcosjr340 Posted October 20, 2021 Share Posted October 20, 2021 On 12/11/2020 at 12:53 AM, SaschaFranck said: This is pretty weird, given that you can revert to previous firmware versions. I'd probably contact the Line 6 support, because apart from the usual update methods (a full reset along with an offline update being the most crucial ones), there's not much other recommendations you may find round these parts. Well ok, maybe you could still try to revert to a previous version, clean all your presets and IRs, then do a factory reset before attempting to update. I tried the factory reset and it didn't work, it only allows the installation of version 2.92 or earlier. The error occurs when trying to install version 3.0 or higher. Quote Link to comment Share on other sites More sharing options...
marcosjr340 Posted December 1, 2024 Share Posted December 1, 2024 On 20/10/2021 at 00:37, marcosjr340 said: Eu tentei a redefinição de fábrica e não funcionou, só permite a instalação da versão 2.92 ou anterior. O erro ao tentar instalar uma versão 3.0 ou superior. O erro permanece, tentei instalar a versão 3.8 e deu o mesmo erro, trava não concluí e eu acabo precisando instalar a versão 2.92 que é a ultima que ele permite instalar Quote Link to comment Share on other sites More sharing options...
