bsimmons106 Posted January 9, 2021 Share Posted January 9, 2021 I just got a helix LT earlier this week and after finally getting a grasp on how this thing works (at least the basics) I’m trying to figure out the best strategy for setting up my presets. I could use some advice/feedback to make sure I am thinking about this the right way. I play in a cover band and I like to use my amp when I practice (I’m not ready to give up the amp in the room feel). But I also want to be able to go directly into a mixer for live shows/monitoring/recording, etc. I’ve tested going into my combo amp using the 1/4 out in the Helix into my power amp in jack on the effects loop. I like the way this sounds after I EQ it a bit, so I’m thinking about splitting the signal path so I can EQ the amp signal prior to going to my amp only. Then sending the other path to PAs. I would also like the reserve the ability to use the Global EQ for adjusting my PA sound on the fly for different venues etc (excluding the 1/4 path for my amp). So my thought is this: Use my XLR outs to go directly into the PA/mixer for shows. Split my signal path after my effects so one output goes to my combo amp’s powercab in using the 1/4 out, so I can EQ that path only. Utilize the Global EQ to adjust for shows using the XLR out only. Anyone else do it this way? Any thoughts before I spend countless hours building my presets? One other thing – I’ve been dialing everything in using FRFR headphones and it sounds great. However I’ve noticed that when I add an EQ to the path for my combo amp (1/4 out), the EQ is also adjusting my headphones output…I guess helix groups the headphones jack in with the Guitar out 1/4? Is there a way to send the 1/4 out to EQ to only the amp, and not my headphones? TIA. Quote Link to comment Share on other sites More sharing options...
waymda Posted January 9, 2021 Share Posted January 9, 2021 Hi I doubt there's a 'best way' other than what suits you. The simplest way I can think of is: Use path 1 for a range of effects that run before your amp Use a split block as late as possible in that path (1b) to create an output tap to the 1/4 inch outputs - I would put an EQ of choice on this path Send the output of path 1a into path 2 Use path 2 to replicate your amp/cab sounds and any post microphone effects to get your desired direct to the board sound - I would have at least one amp, one cab, and EQ and a compressor Set the output of path 2 to XLR Only use the global EQ if you really have to - it will affect all outputs Some of the thinking/options here: You want your amp onstage and the send to the desk to sound similar so need an amp and cab going to the desk Tuning the EQ for the room on the XLR send is best left to the desk rather than your sense of how it needs to be tuned - hence not using global (at least for the XLRs) You will need to test your XLR sends at 'stage' volumes, through good monitors or PAs to ensure they are OK - headphones won't cut it If you have an effects send on the amp you can introduce loops and 4 chan method in Path 1 but it will get complex You could probably go with a 2 amp stereo set-up for the desk if that what you wanted - you will then have a stage sound that is different to the desk send, but IRL the desk doesn't 'hear' what you do I can quickly make a patch for you to play with if you like. Quote Link to comment Share on other sites More sharing options...
waymda Posted January 10, 2021 Share Posted January 10, 2021 Super quick demo of the pathing - all blocks just dropped on the paths, no editing Amp and desk.hlx Quote Link to comment Share on other sites More sharing options...
bsimmons106 Posted January 10, 2021 Author Share Posted January 10, 2021 @waymda Awesome, thanks for this. Quote Link to comment Share on other sites More sharing options...
