HX Stomp Outputs as dual mono
AndresBolivar1
Hi! I have an HX Stomp and a bunch of pedals (Drives, Mod, Time, etc). I want to route the outputs so that an output sends the signal with the amp/cab sim to FOH and the other output sends a signal without the amp/cab sim to a real amp.
So, this is my signal chain:
GTR -> HX Stomp(Comp + Octave) -> FX Loop L (All my drives) - > HX Stomp (Amp/cab + Tremolo) -> FX Loop R (All my mod/delay/time-based pedals) -> HX Stomp (Reverb) -> OUT
If it's not clear enough, what I want to do is this:
GTR -> HX Stomp(Comp + Octave) -> FX Loop L (All my drives) ----------------------------------------------------------> FX Loop R (All my mod/delay/time-based pedals) -> OUT L (To Amp)
        º--> HX Stomp (Amp/cab + Tremolo) -----(Maybe here insert Loop R)--> HX Stomp (Reverb) -> OUT R (To FOH)
Basically what I'm trying to do is use both my amp and the signal with the amp sim in a live situation with 2 independent signals. Is it posible? Thank you in advance!
A.B.
14 hours ago, AndresBolivar1 said:
Is it posible?
You can't have three FX loops.
FX-R has to go either on path A or on path B. It can't go after the mixer because it's mono and it would mix both paths back to mono signal.
Or you'd use only one FX Loop before the Y split.
Or you put your drives before the Stomp.
