lauwing Posted January 29, 2021 Share Posted January 29, 2021 For example, 1. Footswitch 1 assigned to toggle Amp Drive min: 5 max: 10, so that it works as a drive switch 2. When I am in Snapshot 1, I click Footswitch 1, now Amp Drive is set at 10 3. Then I want to switch to Snapshot 2 during a song to turn on additional Delay and Reverb, but when I saved Snapshot 2, Amp Drive was at 5. However, I want to keep the drive setting at 10 when switching Snapshot. I have to tap Footswitch 1 again to set Amp Drive back to 10. I wonder if there is a setting that allow Snapshot mode bypassing those settings? Just like it can bypass a block's on/off state? I know I could just use a drive pedal instead of changing the amp drive parameter, but then it will occupy a block and more DSP in the HX Stomp. thank you Quote Link to comment Share on other sites More sharing options...
lauwing Posted January 30, 2021 Author Share Posted January 30, 2021 I might have been confused by the snapshot bypass thing. What I wanted to achieve is to let the Footswitch 1 parameters not affected by snapshot changes. thanks Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 30, 2021 Share Posted January 30, 2021 42 minutes ago, lauwing said: I might have been confused by the snapshot bypass thing. What I wanted to achieve is to let the Footswitch 1 parameters not affected by snapshot changes. thanks Actually, that's the way it's supposed to work. A parameter should not be affected by a Snapshot UNLESS it's ASSIGNED to SNAPSHOTS. Yet, with a parameter assigned to FOOTSWITCH 1, MIN 5 MAX 10, If I save a Preset with a different Value, say, 8, that Value will be recalled by that SNAPSHOT, even though it's assigned to a Footswitch, NOT SNAPSHOTS! You may have discovered a BUG! I'm attaching a demo preset, if anyone can explain this? Snapshot Bug.hlx Quote Link to comment Share on other sites More sharing options...
lauwing Posted January 30, 2021 Author Share Posted January 30, 2021 Thanks. I thought that maybe the case. So your helix behaves the same in 3.01? Where can I open a ticket? 8 hours ago, rd2rk said: Actually, that's the way it's supposed to work. A parameter should not be affected by a Snapshot UNLESS it's ASSIGNED to SNAPSHOTS. Yet, with a parameter assigned to FOOTSWITCH 1, MIN 5 MAX 10, If I save a Preset with a different Value, say, 8, that Value will be recalled by that SNAPSHOT, even though it's assigned to a Footswitch, NOT SNAPSHOTS! You may have discovered a BUG! I'm attaching a demo preset, if anyone can explain this? Snapshot Bug.hlx 4.08 kB · 0 downloads Quote Link to comment Share on other sites More sharing options...
emanuelcecilio Posted December 22, 2022 Share Posted December 22, 2022 I was searching for a solution for the same issue... and then i've found i'm not the only one. I've been trying to solve this with no luck yet. Quote Link to comment Share on other sites More sharing options...
Bonzai7 Posted January 11, 2023 Share Posted January 11, 2023 Pressing and holding a parameter such as amp drive will change the screen to Parameter and Controller. When a footswitch is selected as Controller a second page becomes available with Snapshot Control (On/Off). I think this is the behavior you are looking for. 1 Quote Link to comment Share on other sites More sharing options...
