johannfrank Posted February 2, 2021 Share Posted February 2, 2021 Hello! Big fan here. I'm just still waiting on ONE update specifically: That you enable stomping on FS1+FS2, and FS2+FS3 *IN STOMP MODE*, to go to the previous or next bank of presets. Right now this is only possible in Scroll, Preset and Snapshot modes. Whereas Live, I spend most of my time in Stomp mode, using the pedal as a pedal board. As a result I've had to buy an external footswitch to swap stomp modes, in order to go to the next song's pedalboard, whereas if you just implemented this option in Stomp Mode it would make life infinitely easier. Thanks for looking into it! Quote Link to comment Share on other sites More sharing options...
phil_m Posted February 2, 2021 Share Posted February 2, 2021 The reason they didn't do this is because in Stomp Mode, the footswitches activate immediately on the press, not the release. If they activated on the release, then having a function for pressing two at the same time could be possible. Doing this would also eliminate the possibility of having a momentary setting available for the stomp switches. One other thing I'd mention is that if you bought a double external footswitch, you might want to look at setting it up to be Bank Up and Bank Down rather than just switching modes. If you hit Bank Up while you're in Stomp Mode, you'll temporarily be taken to Preset Mode as you're describing, and you'll back to Stomp Mode after selecting the new preset. That might be a little easier than switching modes. Personally, I find it a lot easier to bank up or down hitting only one footswitch versus two. Quote Link to comment Share on other sites More sharing options...
