jmg3644 Posted February 8, 2021 Share Posted February 8, 2021 Can the Line 6 Pod Go do dual amp path sending? One sending full amp and cab sim to the foh mix and sending the other one without a cab sim to a power amp and a 1x15 cab for stage volume when needed? Sometimes it's nice to use a cab for stage volume vs a frfr speaker. Thanks Quote Link to comment Share on other sites More sharing options...
spaceatl Posted February 12, 2021 Share Posted February 12, 2021 Yes it can...But it isn't a dual amp path. Rather, you can set the system option for the AMP OUT to be Pre/IR and the AMP OUTPUT will be the signal after the amplifier and before the IR...Note, if you want all the post effects in the AMP OUT you will need to move the cab block to the end of the chain. Quote Link to comment Share on other sites More sharing options...
