Sign in to follow this
Franco_585
Stagescape line in/out routing
Hello all, I could use a little help! I’m trying to find out if/how to rout inputs 1 -10 to monitor a/b out, and inputs 11 & 12 to monitor c/d out. Thank you in advance!
Routing Channel Audio To A Target MonitorIn Monitor Mode there are 3 easy steps involved in sending a channel’s audio to a target monitor, as follows:1. Select the target monitor on the stage by tapping it.2. Set the source channel’s Linked/Unlinked mode as desired by tapping its button. 3. Turn the source channel’s assigned encoder to the desired monitor level.As you adjust each channel’s monitor level, you’ll see an animated signal flow displayed from the source channel to the target monitor. To route audio to a different target monitor, simply tap the monitor’s icon on the stage and you’ll see its controller strip pulsate bright blue, along with the target triangles that rotate around the monitor’s stage icon (see Page 5•1). Then adjust the source channel’s monitor level as desired by turning its assigned hardware encoder.
Pg 5•3
