elbe5050 Posted February 24, 2014 Share Posted February 24, 2014 Hi All, I have a Variax 500 guitar and just cannot get Variax Workbench to find the guitar. I'm using the Variax USB Interface which seems to be working. The Line 6 Monkey (V1.65) finds it and both USB and guitar side LEDS are green. I have tried everything I can think of like re-installing the USB driver (V1.0.7.2), USB Firmware (1.03), plugging into different ports on PC. Batteries in the Guitar are good. Have also tried powering the guitar via A/B foot switch. Any help or suggestions would be greatly appreciated. Cheers, Luke Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted February 24, 2014 Share Posted February 24, 2014 Hi All, I have a Variax 500 guitar and just cannot get Variax Workbench to find the guitar. Batteries in the Guitar are good. Have also tried powering the guitar via A/B foot switch. Well you seem to have done most of the obvious things. Just to eliminate it, have you tried powering from the A/B footswitch with the batteries removed? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 24, 2014 Share Posted February 24, 2014 make sure you have a 1/4" plug connected to the Variax input (it's the power switch), and that the Variax Vol knob is not set to zero (puts the Variax power into sleep mode). Quote Link to comment Share on other sites More sharing options...
elbe5050 Posted February 24, 2014 Author Share Posted February 24, 2014 Hi, Thank you for your replies. Yes, I have got a 1/4" cable plugged into the guitar and no, I hadn't tried it with the battery pack removed, but I will and report back. I only have one RJ45 cable at the moment. It is new, but I'll get another one tomorrow just in case it's not right. Should this just a standard Ethernet cable (Not a crossover cable)? There does seem to be a poor connection on the guitar side RJ45 as its LED does go to red if I jiggle the cable around, but it is green normally. Could there be any problems with the interface electronics within the guitar? The guitar itself seems to work and sounds fine. Thanks again for any suggestions you can think of. Cheers, Luke (Australia) Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 24, 2014 Share Posted February 24, 2014 ....Should this just a standard Ethernet cable (Not a crossover cable)? ... Could there be any problems with the interface electronics within the guitar?.... Yes and yes (but unlikely, and a last resort conclusion after everything else has been ruled out) Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted February 24, 2014 Share Posted February 24, 2014 If Monkey sees your Variax than the interface is talking. What version of Workbench are you using??? Quote Link to comment Share on other sites More sharing options...
elbe5050 Posted February 25, 2014 Author Share Posted February 25, 2014 Hi again. I don't think that Monkey actually sees the guitar. It sees the USB interface, but there is no indication that the Variax is visible. I have attached a capture of the details. Thanks again. Cheers, Luke Quote Link to comment Share on other sites More sharing options...
elbe5050 Posted February 27, 2014 Author Share Posted February 27, 2014 Hi again. Well I've tried everything I can think of and still no good. I can see Workbench trying to connect for an instant (green LED flashes on the USB side) but nothing on the guitar side (LED stays green. No flashing). Could the guitar side LED be green but still have a faulty interface? Are there any other diagnostic tools available that may show a little more of what's going on? Maybe make more attempts to connect, say for around 10 seconds rather than a few milliseconds. Thanks again. Luke Quote Link to comment Share on other sites More sharing options...
elbe5050 Posted February 27, 2014 Author Share Posted February 27, 2014 Hi again. Well I fixed it :D It turned out to be in the guitar's RJ45 socket. Looking into the socket I noticed that the inside end has a structure that is designed to keep the electrical contacts separated. Well it looked like it had somehow been crushed and this made some of the contacts short together. Using a thin sewing needle I forced the plastic separators back into shape so that the contacts would not short. I then plugged the Ethernet cable into the guitar, connected it to the USB interface and YES! it works :lol: Cheers, Luke Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted February 27, 2014 Share Posted February 27, 2014 That often happens when one accidentally tries to plug the 1/4 inch into the RJ45. Easy to do and it damages the pins as you found out. The JTV has a hinged cover over it. The old Variax came with a rubber plug which usually gets misplaced if you use the RJ45 much. Glad you fixed it! Quote Link to comment Share on other sites More sharing options...
elbe5050 Posted March 15, 2014 Author Share Posted March 15, 2014 Hi All, Thank you all for you replies and help. Your feedback helped me to find the cause of the problem and fix it. Cheers, Luke Quote Link to comment Share on other sites More sharing options...
