usedbyanr Posted March 8, 2021 Share Posted March 8, 2021 I was in Pod Go Edit playing with a Wah pedal and noticed that switching the Wah pedal model stopped the pedal from doing anything to the sound when moved through it's range. I then turned the pedal off in Pod Go Edit and then back on. The pedal worked as expected after that. I then tried to recreate the problem but this time I looked down at the Pod Go screen before turning the pedal off/on in Pod Go Edit. The pedal icon on the Pod Go was dimmed which means the Pod Go thinks the pedal is turned off. Pod Go Edit was showing it as turned on. It seems like Pod Go Edit has lost sync with the Pod Go pedal state. Turning it off in Pod Go Edit syncs it again. This seems like a Pod Go Edit bug. Am I missing something before I report it? Simple steps to recreate... 1) Go to a new preset. 2) Select the Wah pedal. 3) Push the pedal toe switch to change to the wah. 4) Change to a different wah pedal in Pod Go Edit. 5) Try the wah. 6) Look at your Pod Go. (Is the on/off state out of sync with Pod Go Edit?) 7) Toggle the pedal off the back on in Pod Go Edit. 8) Try the wah again. Quote Link to comment Share on other sites More sharing options...
