Can I set up Volume without using up one of the 8 foot switches?
jjengle
Yes, just assign the channel volume of the amp model to the expression pedal mode you prefer, EXP 2 or EXP 1, and set the min and max reachable values.
EDIT:
just a small clarification:
in reality, the volume block is usually assigned to the dedicated toe switch under the pedal, and not to one of the 8 available footswitches which therefore remain free to be assigned to other effects or amps.
I hope I am not mistaken in believing that in your question by saying "one of the 8 footswitches" you actually meant to say "one of the 8 available effect slots/blocks".
In fact the one above is intended as an answer to the (reformulated) question:
can I control the volume without having to sacrifice one of the only 8 blocks available?
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
Edited by hurghanico
