4 Cable Method + FRFR unit
RockinMorroccan
Hello all - Apologies if this topic has been covered elsewhere.
I am interested in purchasing the Pod Go. I have an amp with an fx loop and an FRFR speaker. If I run the amp in the fx loop, I would be turning off the amp/cab sim. Will the main L/R outs still be able to use amp/cab sim if I want to simultaneously run to the FRFR unit?
Many thanks
V
it's doable....You need to set the AMP OUT to PRE/IR. Do not turn off the CAB/IR block
wire up
GTR->GO GTR Input
GO FX Send-> AMP GTR Input
AMP FX Send->GO FX RTN
GO AMP OUT->AMP FX Return
You may want to put the CAB/IR block at the very end of the chain if you want post FX in both the FRFR and the AMP...If not, just put whatever FX you want only in the FRFR after the CAB/IR block...Good luck.
  • 2 weeks later...
