jakemarionmusic Posted March 18, 2021 Share Posted March 18, 2021 I would like to send amp a to a power amp and cabinet but send a cab emulated over XLR. I would like to route amp B the same through the right outputs. Is this possible? Amp A ---preamp only---1/4 L -mic cab sim---xlr L Gtr Amp B ---preamp only---1/4 R -mic cab sim---xlr R Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted March 19, 2021 Share Posted March 19, 2021 you can split left and right you can't split 1/4 and xlr your left and right can be different your left will be the same on 1/4 and xlr your right will be the same on 1/4 and xlr Quote Link to comment Share on other sites More sharing options...
jakemarionmusic Posted March 19, 2021 Author Share Posted March 19, 2021 12 minutes ago, pianoguyy said: you can split left and right you can't split 1/4 and xlr your left and right can be different your left will be the same on 1/4 and xlr your right will be the same on 1/4 and xlr Can you send a mono single amp chain into an amp and to the board via XLR simultaneously without a cab emulation into the amp? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted March 19, 2021 Share Posted March 19, 2021 1 hour ago, pianoguyy said: you can split left and right you can't split 1/4 and xlr your left and right can be different your left will be the same on 1/4 and xlr your right will be the same on 1/4 and xlr Quote Link to comment Share on other sites More sharing options...
jakemarionmusic Posted March 19, 2021 Author Share Posted March 19, 2021 21 minutes ago, pianoguyy said: Thats an awful configuration to leave out. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted March 19, 2021 Share Posted March 19, 2021 with the memory limitations of a decade old product, and the programming limits of 8 fx and 2 amps.... i think it was best to assume that those going direct would go direct and those using an amp would use an amp. you don't need to allow both. Quote Link to comment Share on other sites More sharing options...
jakemarionmusic Posted March 19, 2021 Author Share Posted March 19, 2021 14 minutes ago, pianoguyy said: with the memory limitations of a decade old product, and the programming limits of 8 fx and 2 amps.... Except you can't even do it with a single mono amp block. I don't see where the memory limitation is. Also the rp1000 the boss GT Pro and the behringer vamp all had the ability to go direct and monitor your guitar and the GT Pro even did it stereo which are from three different companies and all three of those products were cheaper and came out before the pod Pro X. Quote Link to comment Share on other sites More sharing options...
jakemarionmusic Posted March 19, 2021 Author Share Posted March 19, 2021 16 minutes ago, pianoguyy said: i think it was best to assume that those going direct would go direct and those using an amp would use an amp. you don't need to allow both. you don't think it would be useful to be recording straight to the board on a session with whatever emulated rig you have but monitor through a real guitar amp? That's extremely useful on stage. They're competitors at the time thought it was a good idea and they seem to think it was a good idea to include on the helix which lets you tap out. Quote Link to comment Share on other sites More sharing options...
