FilGusev Posted March 21, 2021 Share Posted March 21, 2021 Hi, everyone There is an issue with my Helix. I've noticed that poly pitch shift time feature does not work on it. It's a new unit, everything else works fine. I made an update for version 3.01 too. Do you know what could possibly be a reason for that? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 21, 2021 Share Posted March 21, 2021 1 hour ago, FilGusev said: that poly pitch shift time feature does not work You are not making this very clear. Do you mean that the "Poly Pitch" block actually can be selected, but the "Interval" and "Shift Time" do not work? 1 hour ago, FilGusev said: I made an update for version 3.01 too. Do you know what could possibly be a reason for that? If you updated your Helix to v3.01 you should be able to select the "Poly Pitch" block from within the menu - Pitch/Synth >Mono> Poly Pitch. If this is available to you on the Helix hardware, but it doesn't appear in the your HX Edit program, the please ensure that the HX Edit version is also v3.01. If you cannot find Poly Pitch on the Helix hardware then you must ensure that it is definitely updated to v.3.01 firmware. Hope this helps/makes sense. 1 1 Quote Link to comment Share on other sites More sharing options...
FilGusev Posted March 21, 2021 Author Share Posted March 21, 2021 Hi Thank you for helping, I've sorted that out. Regards Fil 1 Quote Link to comment Share on other sites More sharing options...
