kswan Posted March 27, 2021 Share Posted March 27, 2021 Not sure why software would have a check for update feature that doesn't check for software updates but only checks for firmware updates but that appears to be the case with pod go edit. I assumed the check for updates would check and install software updates as well as firmware but not the case. Also not sure why if that's the case that line6 doesn't prompt one to update said software before updating firmware if that's what's required but that is the case as well. So, edit updated the firmware before I knew to update the software first and now the pod go firmware is up to date, and the pod go edit is up to date, but none of the new features are showing. I do know what I'm doing so I've trashed pod go edit and all associated preferences, restored pod go to factory settings, reinstalled pod go edit, connected pod go, booted, and still no new models showing. I've tried this on 2 different computers with the same results. I'm on a mac. The super annoying thing about this whole process is that a simple message of warning to update the software first could have solved this issue. Quote Link to comment Share on other sites More sharing options...
Monstajam Posted March 27, 2021 Share Posted March 27, 2021 Same exact thing here bro. I have updated everything via Go edit and I see none of the new stuff. Quote Link to comment Share on other sites More sharing options...
DoozyDKM Posted March 28, 2021 Share Posted March 28, 2021 I made the same mistake & nothing new appeared. So I ran the software update, restarted the PC and the Pod Go and everything seems fine now. Maybe it's different on a Mac but I agree it should be made harder to install them in the wrong order. Maybe try re-installing on a friend's PC if that's an option? Hope you get it sorted. Quote Link to comment Share on other sites More sharing options...
kswan Posted March 28, 2021 Author Share Posted March 28, 2021 The latest I posted on the db forum for any Mac users experiencing issues with older OS. Yosemite Mac users make note on update. See my prior post for the difficulties updating pod go. It seems like Yosemite and the new version of pod go edit weren’t liking each other. It’s the OS I’ve been using since getting pod go and I’ve had no issues. It appears that pod go edit was not seeing any updates for pod go however. So the pod go looked like it was up to date but wasn’t. I booted into a High Sierra partition on another computer, installed latest pod go edit, and it immediately saw pod go and found the available update. Once updated I was able to go back to my laptop with pod go edit and the unit was fine and updated and pod go edit working as it should. Thanks to all for the tips. They didn’t work in this case but they are committed to my future troubleshooting memory banks. Cheers! Quote Link to comment Share on other sites More sharing options...
