Weird Snapshot Issue
akharder
Never had this issue before. Using one of my templates and made some changes by moving blocks around by copying, pasting, and deleting. Afterward I wasn’t able to switch to snapshot 2 or 3. Loaded the original template back in. Snapshots work as normal. Began clearing blocks one by one. No problems. When I paste one particular block (transistor tape) on the B path then I can’t select snapshots 2&3 and sometimes none except for a random one. If I manually set up the block no issues but if I copy that block and put it anywhere else it locks up the snapshots. Anyone else ever dealt with this before?
I've had issues copying and pasting entire patches into different slots and having it end up corrupted... seems a little odd that it would happen with just one block, but I suppose anything is possible. If that block is something that you're gonna use regularly, save it to "favorites", and then grab it from there instead of copying and pasting each time. See if the same thing happens...
