davidstvz Posted March 30, 2021 Share Posted March 30, 2021 Is there any way to do a notch filter using the Pro HD500? I have an acoustic with piezo pickup that has a nasty resonance right around 3100 hz and I just want to put a notch as narrowly as possible right there at 3000 or so. I don't see any good way to do that. On that subject, I don't see any good documentation for the EQs. What is the shift EQ for example? Quote Link to comment Share on other sites More sharing options...
hurghanico Posted March 30, 2021 Share Posted March 30, 2021 Use the Parametric EQ.. Here is a useful video clip showing how to use it as a notch filter.. and here you can see a table with the correspondences between values expressed in percentages in the Parametric EQ in the POD and the values in Hz: http://foobazaar.com/podhd/toneGuide/eq#effects-param _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips 1 Quote Link to comment Share on other sites More sharing options...
davidstvz Posted April 6, 2021 Author Share Posted April 6, 2021 Thanks, that is helpful, though I feel like the notch is still a little too wide at max Q settings (it's not a true notch, just a deep narrow cut). This guitar is under warranty still, so hopefully I can get this fixed and won't need the notch. It's probably just the placement of the piezo pickup. It's sad that Line6 doesn't document these EQs better. They are really very poorly explained in the manual. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted May 12, 2021 Share Posted May 12, 2021 You'll want to take a look here and download the "Huge 185M EQ frequency response file (zip)" linked at the bottom. That shows what the frequency response of ALL the EQs look like, including the parametric EQ and the various Q settings. There's lots of other cool geeky stuff there as well. Enjoy! Quote Link to comment Share on other sites More sharing options...
