edwiny13 Posted April 12, 2021 Share Posted April 12, 2021 Hi everyone. A few months ago I bought a POD HD500. So far I am satisfied with the entire effects section, however I feel that the cab simulations is the weak point of this kind of digital stuffs. So I'm thinking of reinforcing it with some affordable IR on the market. I am evaluating the Mooer Radar, since I have seen that people usually combine it with the POD, or a Nux Solid Studio (this last one, I havent seen yet in combination with the POD). So what do u think ... Mooer Radar or Nux Solid Studio? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 13, 2021 Share Posted April 13, 2021 Call me an elistist. Call me a purist. Hell, call me an old fuddy duddy. But what ever the case might be.... If you bought an amp modeler, and don't like the models in it ------- you simply bought the wrong unit. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 13, 2021 Share Posted April 13, 2021 Because you bought an HD500 - make sure the firmware is updated. It could make a difference. Quote Link to comment Share on other sites More sharing options...
JohannDaart Posted April 13, 2021 Share Posted April 13, 2021 If you can get used IR loader for cheap, why not? But if you want to spend another $100 for a new one, then I think it's better to sell HD and get something new with IR already built in. Quote Link to comment Share on other sites More sharing options...
edwiny13 Posted April 13, 2021 Author Share Posted April 13, 2021 16 hours ago, pianoguyy said: Call me an elistist. Call me a purist. Hell, call me an old fuddy duddy. But what ever the case might be.... If you bought an amp modeler, and don't like the models in it ------- you simply bought the wrong unit. Yeah, i'm just thinking on making some little upgrades to the POD not a big deal... Quote Link to comment Share on other sites More sharing options...
edwiny13 Posted April 13, 2021 Author Share Posted April 13, 2021 8 hours ago, JohannDaart said: If you can get used IR loader for cheap, why not? But if you want to spend another $100 for a new one, then I think it's better to sell HD and get something new with IR already built in. Its an option... right away i'm saving some money to buid my own pedalboard but in the meantime i'd like to get most out of the POD. That's why i looked up to the Radar or the Nux. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted April 13, 2021 Share Posted April 13, 2021 Before buying an IR loader box it would be advisable to try one in plugin format to get an idea of what the results would be in using external IRs in place of the POD cab models (which for the record are also based on IRs).. Here follows an old post by Logidy, the maker of an IR loader device: _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
edwiny13 Posted April 14, 2021 Author Share Posted April 14, 2021 16 hours ago, hurghanico said: Before buying an IR loader box it would be advisable to try one in plugin format to get an idea of what the results would be in using external IRs in place of the POD cab models (which for the record are also based on IRs).. Here follows an old post by Logidy, the maker of an IR loader device: _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Ohh! very useful info. I have a laptop and i'd like to prove some of these IR. What is the connection i need to follow to achieve this? Quote Link to comment Share on other sites More sharing options...
hurghanico Posted April 14, 2021 Share Posted April 14, 2021 1 hour ago, edwiny13 said: Ohh! very useful info. I have a laptop and i'd like to prove some of these IR. What is the connection i need to follow to achieve this? Use a DAW software (eg Reaper, Cubase, etc.) and set the POD as its audio interface, find online and install an IR loader plugin you like, select a track in the DAW and arm it for recording and apply the IR loader plugin as an effect, enable track monitoring in the DAW, and via the POD audio driver control panel disable direct hardware monitoring, disable the amp model cab in the POD patch and load your IRs through the IR loader, to reduce latency as much as possible of your live playing reduce the driver buffer (again via the control panel of the driver) to the value just before the one where audio problems such as interruptions, crackles etc. start to happen. Discover the external IRs world... (obviously you need to already have some IRs at your disposal to try) _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
