Buffers with HX Stomp
johnpannella
I have a question about using buffers with the HX Stomp.  I am putting together a small pedalboard that will include my HX Stomp and 3 other pedals that will most likely be a Clean Boost, Transparent Overdrive, and slightly higher gain overdrive.  Should I use a buffer since I am going to have 3 pedals feeding into the HX Stomp which I will use for effects only, no amp models or cabs and also no overdrive/distortion/fuzz.  I typically use a dual buffer such as the Mesa High Wire of the Empress Buffer+.
