Gkf9 Posted May 24, 2021 Share Posted May 24, 2021 Can anyone please tell me how I connect my ditto looper up at the back of the Helix effects please. I'm already running the Helixi 4cm with my Blackstar amp. Many thanks. Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 24, 2021 Share Posted May 24, 2021 5 hours ago, Gkf9 said: Can anyone please tell me how I connect my ditto looper up at the back of the Helix effects please. I'm already running the Helixi 4cm with my Blackstar amp. Many thanks. Hi, Should be simple enough to patch your Ditto looper into the second send and return on your HX Effects. You will need to decide where you need to place the FX send and return in your signal chain. It will most likely depend on what effects need to be added to the signal before going into the Ditto. I have a Ditto x4 (among others) which I use with my Helix floor. I sometimes have the “amped” guitar with any overdrive effects into the looper and added delay and reverb after the Ditto. There are no strict rules with this stuff - just use whatever works for you. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
Gkf9 Posted May 28, 2021 Author Share Posted May 28, 2021 Thanks for the reply, so if I wanted a OD sound in the loop I'd put it before the loop, could I then play over the loop with over drive sound too? Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 28, 2021 Share Posted May 28, 2021 1 hour ago, Gkf9 said: Thanks for the reply, so if I wanted a OD sound in the loop I'd put it before the loop, could I then play over the loop with over drive sound too? That would do it. Anything before the looper goes into it, that's why I leave delay and reverb until after the return. Have fun! Quote Link to comment Share on other sites More sharing options...
