Johnnathan1 Posted May 31, 2021 Share Posted May 31, 2021 Dandelions, with their tiny yellow bouquets and fluffy seed puffs, may be a nuisance to gardeners once they pop up wherever they're not wanted. Above ground their seeds ride the wind currents to propagate the species. And below ground the weed sends down a taproot up to 10 inches long that is usually difficult to eliminate in its entirety. Gardeners typically approach dandelion removal in two ways: pulling the plant or spraying it with herbicide. When to remove Dandelions Dandelions are broadleaf, herbaceous perennials that die back in the winter, though the plant's roots live on underground.1? In the early fall, nutrients are transferred from the leaves to the roots, making this the best time to use herbicide. Chemicals applied during this time will be absorbed by the leaves and passed on to the roots along with the nutrients. How to get rid of Red Wine Stains From Carpet You can harvest and eat dandelion greens in the spring.2? The leaves might be boiled or used raw in a salad. This superfood is rich in vitamin A, vitamin C, and iron. Moreover, the flower might be used in wine or boiled and stir-fried. And the roots may be dried and steeped for a tea. For the best taste, harvest dandelion greens and dig up their roots before the plant goes to seed. Warning When pulling dandelions to eat, avoid harvesting near roads in which road salt or other toxins might be present. Likewise, don't harvest from a lawn in which herbicides and other chemicals have been used. Always thoroughly wash the dandelions before consuming. What You'll Need Equipment / Tools Garden spade or pitchfork Gardening gloves Protective clothing Garden hose or sprinkler Pump sprayer Dandelion puller (optional) Materials Broadleaf herbicide Grass seed Instructions Hand-Pulling Dandelions As with any weed-pulling method, persistence is key. It might take several seasons to fully eradicate dandelions in your garden. Plus, dandelion roots can easily split as you pull them, and any fraction left behind will regenerate the plant. Water Area Water the area with the dandelions to loosen the soil, and then wait for about half an hour. Weeds are more easily extricated from wet soil. Make an Incision in the Soil Using a garden spade or pitchfork, make an incision in the soil alongside the taproot (the long, thick root growing deep into the ground). Wiggle the tool to loosen the taproot. Pry up the Dandelion Grip the leaves, and tug them gently until the taproot comes out of the earth. Make Further Incisions, if Necessary If there is still too much tension on the taproot for the plant to slide out of the soil, make further incisions around the root. Then, continue to tug gently at the leaves until it comes free. Reseed Area Reseed the area with grass seed, and water any bare spots. Killing Dandelions With Herbicide It's best to avoid using chemicals when alternative weed protocols exist. However, if your pulling efforts don't eliminate the problem, you might want to use a broadleaf herbicide as a last resort. However, make sure you check safety warnings on the product for kids, pets, and the environment. And verify that it won't kill wanted plants, including your grass. Select Herbicide Select an appropriate broadleaf herbicide. Choose a Sunny Week Check the weather, and wait for a sunny, dry week. Prepare the Herbicide in Your Pump Put on gardening gloves and protective clothing. Add the herbicide to your pump sprayer, mixing it with water per package directions. Apply Herbicide Using the sprayer, apply the herbicide to the dandelions in your lawn. Allow it to dry. Wait Wait several days until the dandelions' foliage turns brown before you water your lawn again. Reseed Area Once dead, pull out or rake up the dandelion remains. Reseed the area with grass seed after waiting at least three days from the chemical application. Tips for Removing Dandelions If you're serious about nontoxic removal methods, purchase a dandelion puller. This garden tool is specifically built to get the job done. Horticultural vinegar (made of 20 percent acetic acid) can be used in place of a chemical herbicide. The high level of acetic acid gives it a herbicidal punch. But note that vinegar kills grass, so be very careful during application. For at least two or three days before applying herbicide, don't mow the lawn. The bigger the dandelion leaves are, the more effective your application will be. Likewise, wait at least two or three days before mowing after your application to allow time for the chemical to be transferred to the roots. For more info: https://backyardmash.com Preventative Dandelion Control Promoting lawn health is the best method of dandelion control. Don't think of your grass as a passive partner needing rescue from weeds. If managed properly, your lawn can compete against weeds, eliminating the need for laborious dandelion removal. Leave grass clippings on your lawn.3? They will act as a mulch to prevent weed seeds from germinating. When you mow, leave the grass at a height of 2 to 3 inches. This will allow the grass to "protect its own turf" by depriving weeds of the light they need. And don't let bare spots remain, as they invite the invasion of opportunistic weeds. In the fall, fill in bare spots by overseeding. Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 31, 2021 Share Posted May 31, 2021 6 hours ago, Johnnathan1 said: does anyone have any ideas on what to do now? Hi, HX Effects Reset Options HX Effects Button Combination Description Holding FS3 & MODE Will clear all Presets and IRs Holding FS4 & FS5 Reset Global Settings Holding FS5 & FS6 Reset Presets only Holding FS6 & TAP Factory restore (reset, Globals, IRs, and Presets) Holding the right arrow ">" Will put the unit in a fail safe update mode. Use this when the HX Effects is in an un-recoverable state Don't Panic - It is very rare that a glitch in the firmware will actually turn your device into an paperweight. You mentioned that you were updating your HX Effects to the latest v3.11.0 firmware, but didn't say what version was already installed. The reason I mention this is because, IIRC, with firmware earlier than 2.8, when the main system core was modified, it can cause the unit to appear to have suffered "Boot Failure". It seems to me this usually happens when trying to update from firmware versions prior to the core change and also an error message appears on screen. You didn't say if this happened with your installation. Also all updates should be run from within HX Edit, but in this case we need to by bypass that because your HX FX isn't showing on the USB. - NOTE some front mounted USB Ports on PC's can act as a hub. O.K. Let's try this and see if we can "kickstart" your hardware into update mode. Remove all Line 6 software from your computer especially the Windows drivers and then restart your computer. Make sure to turn off the power to your HX FX. Unplug the USB cable from the computer and HX FX. Hold down the right arrow key ">" and the turn power on and when Helix logo appears, quickly release both foot switches. Leave it powered up. Download the and install latest HX Edit v. 3.01 (with all the drivers) ENSURE THAT HX EDIT IS CLOSED BEFORE ATTEMPTING THE NEXT STEP. Reconnect the USB cable to HX FX and computer - DO NOT USE A HUB. Find and launch the Line 6 Updater and re-install the v.3.11.0 firmware file Hope this helps/makes sense. No guarantees are given or implied, you do this at your own risk. If it doesn't work, raise a ticket with Customer Support. Quote Link to comment Share on other sites More sharing options...
