cordofono Posted June 16, 2021 Share Posted June 16, 2021 il volume del pedale si muove ma non cambiano le percentuali di posizione. Sembra che il sensore non legga più la posizione del pedale. the volume pedal moves but the position percentages do not change. thanks Quote Link to comment Share on other sites More sharing options...
theElevators Posted June 16, 2021 Share Posted June 16, 2021 Click your expression pedal in. There is a toe switch that gets activated when you press your Expression pedal hard. This will switch it between EXP 1 and EXP 2. My guess is that you are moving your expression pedal, but you are in the wrong Expression pedal, that's why it doesn't change. You could also have cleared the volume assignment. Simply delete the volume pedal block and re-add it. Quote Link to comment Share on other sites More sharing options...
