craiglockwood Posted July 8, 2021 Share Posted July 8, 2021 I love my Pod Go and have been using it with my Headrush 112 FRFR. Looking to plug into FOH for larger gigs and still use the Headrush as a monitor (just my guitar). Is there a way to do this and be able to use the main volume knob on the Pod Go to adjust volume of the Headrush monitor only - without affecting the signal to FOH. I know I could use the output of the Headrush to FOH and use the input volume on the Headrush to dial in the monitor volume but it would be SO much easier to do this on the Pod Go. 1 Quote Link to comment Share on other sites More sharing options...
spaceatl Posted July 9, 2021 Share Posted July 9, 2021 I use the GO for bass and gig with a single 15 monitor. I set the AMP OUT to MAIN and that gets a DI for the house. I run the MAIN L (MONO) out to my monitor. works great for me. When I have a gig where backline is provided and I have to use an amplifier I change the AMP OUT to CAB/IR and run the to Power Amp in of whatever it is. Set the MAIN level to noon and take the DI form the MAIN L....For you, I would suggest try setting the AMP OUT to MAIN and use that for DI...Run your headrush off the MAIN. GO Master does NOT affect the AMP OUT. 1 Quote Link to comment Share on other sites More sharing options...
craiglockwood Posted July 9, 2021 Author Share Posted July 9, 2021 Well, that is perfect. Thank you so much for taking the time to answer. Quote Link to comment Share on other sites More sharing options...
