borgis Posted August 1, 2021 Share Posted August 1, 2021 hi so . im getting usb audio through my 2nd path when listening to my project , 1st path is ok. as far as i can see this just shouldn't happen. seems to be related to certain reverbs wtfuzz.hlx wtfuzz.flp Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 1, 2021 Share Posted August 1, 2021 Your patch won't DL. What's the input on the second path set to? Quote Link to comment Share on other sites More sharing options...
borgis Posted August 1, 2021 Author Share Posted August 1, 2021 mic, but it doesn't matter, every input is the same path 2 picks up usb audio Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 1, 2021 Share Posted August 1, 2021 Try uploading your patch again so I can look at it. USB audio goes directly to the outputs, bypassing the signal chain. Quote Link to comment Share on other sites More sharing options...
borgis Posted August 1, 2021 Author Share Posted August 1, 2021 wtfuzz.hlx Quote Link to comment Share on other sites More sharing options...
borgis Posted August 1, 2021 Author Share Posted August 1, 2021 (edited) Just now, rd2rk said: Try uploading your patch again so I can look at it. USB audio goes directly to the outputs, bypassing the signal chain. i know its weird, maybe my 2nd dsp chip is faulty. the helix locks up when i try to add a noise gate to path 2 after moving the split on this but path 1 is ok... Multi Band 4 twd.hlx Edited August 1, 2021 by borgis typo Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 1, 2021 Share Posted August 1, 2021 OK, wtfuzz dl'd, and it's doing exactly what it's supposed to do, sending USB 1/2 to the output assigned in Global Settings>Ins/Outs>USB 1/2 Destination. If you have it set to MULTI, it goes EVERYWHERE EXCEPT USB 1/2. However, it does not (and is not) go(ing) to the Inputs. That patch has Path 1 Out set to Send 1/2 and Path 2 Out set to USB 1/2. I have the 1/4" on my Helix connected to a tube amp return and L6 Link connected to my PC212+, which outputs (via XLR) to a mixer. XLRs on Helix are not connected. If I change the USB 1/2 Destination in Global Settings to XLR, I hear playback in headphones. If I change it to 1/4" it plays back through the amp, and Multi plays back everywhere (except USB 1/2). If I change Input Block source to NONE or any unused input, it has no effect on the signal. No effect added to either path affects the signal. That means that the signal is going to the outputs directly, not through the signal path! Conclusion: The patch works as expected. Review the above and, hate to say it but, RTM. When I first got my Helix, the manual was very confusing, and I had to read it multiple times and try all sorts of experiments before I figured it out. It's a lot like plumbing, which I suck at. FWIW - Multi Band 4 twd.hlx failed the same way that the first DL of wtfuzz did, with a message that the link was trying to DL multiple files. The second attempt at wtfuzz worked, but didn't DL the patch name. IDK what's up, but you might want to run a malware check. Just sayin'..... 1 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 1, 2021 Share Posted August 1, 2021 Just an afterthought, but to be sure it's not a faulty Helix, make sure your Helix FW AND HX Edit are on v3.11, and maybe re-flash the FW for good measure. 1 Quote Link to comment Share on other sites More sharing options...
borgis Posted August 2, 2021 Author Share Posted August 2, 2021 Thanks for taking the time to do that. Ill try the firmware on Tuesday. Quote Link to comment Share on other sites More sharing options...
