optimystery Posted September 1, 2021 Share Posted September 1, 2021 I've seen the linear / logarithmic setting mentioned for the Helix, but no sign of that in the Stomp XL manual or menus. I'm using a Nektar NX-P, and while it works ok, the transition from heel down is very abrupt. Is there a setting to control the response? I know you can set min / max levels for volume / wah, but that's kind of a different thing. Quote Link to comment Share on other sites More sharing options...
optimystery Posted September 6, 2021 Author Share Posted September 6, 2021 Not sure why I didnt see this. It's in the screen menu and HX edit, just not the manual (by keyword anyway) Quote Link to comment Share on other sites More sharing options...
codamedia Posted September 9, 2021 Share Posted September 9, 2021 I'm sure you figured this out... but "Linear/Log" is not an option in the EXP settings, it's an option in the VOLUME Block. Normally you would set this to LOG for a Volume pedal. However.... if you already have an external expression pedal with a LOG curve.... Linear might be more appropriate. (most EXP pedals have linear curves, but not all) 1 Quote Link to comment Share on other sites More sharing options...
