mferrand Posted September 3, 2021 Share Posted September 3, 2021 Hey All, I have a Mission Engineering pedal with a switch. I would like to use it like a traditional Wah pedal with my HX Effects. So, toe down engages the switch and turns the Wah on / off. I have the the control jack of the pedal into EXP 1 with it set for Position. I have the switch jack of the pedal into EXP 2 with it set for Bypass. This does not seem to work. Any idea what I am doing wrong? Cheers, Mike Quote Link to comment Share on other sites More sharing options...
datacommando Posted September 3, 2021 Share Posted September 3, 2021 17 minutes ago, mferrand said: I have a Mission Engineering pedal with a switch. Hi, You don't say which Mission model and they do tend to be product specific, but I going to guess the you have the SP1-L6H. This is the spec from the Mission page, but I have highlighted in bold the relevant info. The Mission SP1-L6H connects to the Line 6 Helix Rack or Rack controller with a single TS cable for expression, and a single TS cable for the toe switch. For use with the HX Stomp, a TRS cable is required. The toe switch function is only supported on the Helix Rack, Rack controller, and HX Stomp. Other Line 6 devices do not have a toe switch input. The switch output may be left unconnected if this function is not required. The Mission EP1-L6 is recommended for other Line 6 products where a toe switch input is not available. Pedal dimensions are 10″ x 4″ x 3″ Weight is 3.2lb Potentiometer is 10K Ohm Linear Switch is TS Momentary Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
mferrand Posted September 3, 2021 Author Share Posted September 3, 2021 Thanks for your reply. The pedal is a Mission Aero EP-25-PRO. I guess the point of my question is... can the switch from the pedal be used to turn the effect on and off? Quote Link to comment Share on other sites More sharing options...
datacommando Posted September 3, 2021 Share Posted September 3, 2021 3 minutes ago, mferrand said: The pedal is a Mission Aero EP-25-PRO. Hi, again, This is the spec from the Mission page The EP-25-PRO features two expression outputs with independent polarity switches for each channel. This allows for compatibility with a wide range of different pedals, rack effects, modeling amplifiers, keyboards and MIDI controllers. The EP-25-PRO is available in black stealth style powder coat, or gold carbon fiber graphic finish. Pedal dimensions are 11″ x 4″ x 3″ Weight is 3.6lb Potentiometer is dual 25K Ohm Linear More details and video here: https://missionengineering.com/support/ep25-pro-aero-electronic-user-guide/ Hope this helps/makes sense Quote Link to comment Share on other sites More sharing options...
mferrand Posted September 3, 2021 Author Share Posted September 3, 2021 Hi, Mine has one expression output and one switch output (latching). I was hoping to use the switch output to turn the wah on and off. Is there a way to do this? Quote Link to comment Share on other sites More sharing options...
datacommando Posted September 3, 2021 Share Posted September 3, 2021 1 hour ago, mferrand said: Is there a way to do this? Hi, I haven’t managed to turn up any specifications for that model with a single switch and output. You might be better consulting Mission Engineering as the will have a definite answer. https://missionengineering.com/support/ Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
mferrand Posted September 3, 2021 Author Share Posted September 3, 2021 Datacommando - thanks for all of your replies. Maybe I just haven't phrased my question properly. This really has nothing to do with the Mission Pedal. So... can I turn the HX Effects Wah block on / off using an external switch plugged into 'Pedal 2' Quote Link to comment Share on other sites More sharing options...
datacommando Posted September 4, 2021 Share Posted September 4, 2021 16 hours ago, mferrand said: Datacommando - thanks for all of your replies. Maybe I just haven't phrased my question properly. This really has nothing to do with the Mission Pedal. So... can I turn the HX Effects Wah block on / off using an external switch plugged into 'Pedal 2' O.K. First, when you add a wah block it’s function is automatically assigned to EXP 1(Pedal 1) and likewise any volume block is assigned to EXP 2 (Pedal 2). You can change this, but it might become confusing. There is no external switching involved other than controlling external amp channel switching or turning reverb on or off. External expression pedal toe switch support is only available on the Helix Rack, and HX Stomp. I couldn’t find a wiring diagram for your pedal, but probably it would simply be a matter of disconnecting the latching switch from the circuit. If you don’t want to use a foot switch on your HXFX to turn on the wah, you could set your Mission Aero EP-25-PRO to engage when it reaches around 3 or 4% of travel from the heel position. Here’s a thread discussing that option. EDIT: Of course you also have the option to use Command Center and Snapshots to control anything with anything else. It's all in the manual. https://line6.com/data/6/0a020a411710a6112a67116f0b/application/pdf/HX Effects 3.0 Owner's Manual - Rev C - English .pdf Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
