tubehead123 Posted September 7, 2021 Share Posted September 7, 2021 Just got a HX Stomp XL with the intention to use the 4 Cable Method. However the unit does not contain the 4CM presets. From the manual - TIP:Look for factory presets starting with “4CM.” Note that these presets will not pass any audio unless hooked up in the method below. I watched a video and was able to get the unit to do what I wanted. The question is, Do factory presets "4CM" exist in the unit as indicated in the manual? Thanks Quote Link to comment Share on other sites More sharing options...
datacommando Posted September 8, 2021 Share Posted September 8, 2021 On 9/7/2021 at 4:37 PM, tubehead123 said: Just got a HX Stomp XL with the intention to use the 4 Cable Method. However the unit does not contain the 4CM presets. From the manual - TIP:Look for factory presets starting with “4CM.” Note that these presets will not pass any audio unless hooked up in the method below. I watched a video and was able to get the unit to do what I wanted. The question is, Do factory presets "4CM" exist in the unit as indicated in the manual? Thanks Hi, You only said that the unit does not contain the 4CM presets, but you didn’t mention if the other factory default presets are in there and fully functional. If your unit is gleaming new straight out out the box the factory presets should all be there. Usually when weird stuff happens, and you cannot find things that should be there, a factory reset will put it back to normal. If you’re absolutely certain that Presets are not there (and possibly all named “New Preset”) you could do a factory reset by holding down the footswitches labelled C & D while powering up. If you have created some of your own presets already make sure to back them up first using HX Edit or they will be erased. You can load them back in later. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
