Help me! Pod hd500x and midi problem
ivanbg
Hi! I have a problem, I use the pod hd500x and an engl invader,
I connect the midi in of the amplifier (configure omni engl) to the pod, I configure omni in the pod, and it changes the channel, that is, it communicates well, I can change the variax preset, the effects preset by fxloop, and the amp channel with its gains, noise gate, volume A / B, etc.
my problem is that when I connect the guitar cable it makes a lot of noise, like fireworks, and it only disappears if I remove the midi, which prevents me from changing the channel of the engl, although if I use the FX loop,
If I do without the 4-wire method, it happens to me that with the guitar's wireless it goes well, but as soon as I put a cable instead of wireless it puts noise again, until I disconnect the midi out of the pod .. I don't understand what happens What is different about the wireless cable? ...
In the end in summary I can use the pod well as long as I use the z15 to change channels. But I want everything from one, that I have already seen that it is possible, but the noise prevents me.
I have to find the one who communicates well via midi and voila
Can you give me any suggestions?
I change the omni of the pod for a specific channel?
Any opinion or criticism is welcome.
