TReBeL Posted September 14, 2021 Share Posted September 14, 2021 Hi all, I am able to run Pod Farm 2.59 (Asio) as a plugin at 24 bit / 96kHz through my Audient ID14 Mk II without any issues (Win10). When I run it in Standalone mode it forces the ID14 into 44.1kHz. When I try to set it back to 96kHz in the Audient software the audio drops. I then have to restart the app and it forces the audio back to 44.1kHz again. The settings in control panel / sounds are set at 24 bit / 96 kHz. The standalone mode at 44.1 kHz sounds TERRIBLE! Nothing like the plugin at 96 kHz! Any ideas? Please help! Cheers, Treb Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted September 15, 2021 Share Posted September 15, 2021 You should hear no difference in sound between the 2 sample-rate settings - from what an online search shows, the difference in sound could be from input gain differences. When running PodFarm as a plug-in the sample rate is controlled by the DAW; when running as stand-alone the sample rate is controlled by the AI settings. I think PodFarm only runs at 44.1/48, and internally converts if a higher sample rate is used. 1 Quote Link to comment Share on other sites More sharing options...
TReBeL Posted September 17, 2021 Author Share Posted September 17, 2021 Thanks Mike, that's pointed me in the right direction! In the plugin the levels are spot on right off the bat with the input and output gains at unity. In the standalone version I need to push the input gain by around 6 - 9 dB from unity to get a decent signal. Without doing that the sounds are really dull and lifeless. On the output side I needed to cut a full 18 dB! It was clipping here before, and between these two adjustments it's sounding a lot better now! Having said all that it still is a bit "grainier" and not as natural sounding to my ears. I agree that I can't hear a difference with most other instruments comparing these sampling rates, but with distorted guitar it is definitely noticeable, especially on high gain amp models. I only came to realize this after reading about it and trying it for myself on my other amp sims. My UX1 is definitely limited to 48kHz, but I would be surprised if the standalone software would be limited on other devices capable of running higher sampling rates, since Podfarm runs quite happily at 96kHz as a plugin. AmpliTube was doing the same thing as Podfarm, until I figured out that I had to start a new "Song" and then set the sample rate to 96k in "Project Settings". Unfortunately I can't find that option in Podfarm. I can select File / New, but when I then click on File / Preferences / Hardware / "Asio Settings" nothing happens (no window opens up). I can only open the Audient software manually and change the settings from there, but then the audio drops as described above. Either I'm missing something or you are right! Thanks again for your help! Cheers, Treb Quote Link to comment Share on other sites More sharing options...
