HX Stomp Delay Tails?
notimerocker
Just learning the ropes on the HX Stomp, but something has me stumped. In snapshot mode, with reverb and delay tails ON, when I switch from a snapshot with a long feedback & decay on the verb and delay to one with shorter, the tails seem to die very quickly. Is there anyway to control this? Think of it this way - I'm going from an ambient snapshot to a non-ambient one and want the ambience to fade out in the background after I switch. Thoughts?
If you’re using the same delay and reverb blocks, what you’re talking about is the expected behavior. Like if you’re reducing the feedback parameter in the new snapshot, what’s happening to the repeats is controlled by the value in the new snapshot. The workaround, if you want to call it that, is to use use different delay and/or reverb blocks per snapshot.
8 minutes ago, notimerocker said:
Thanks for the response. Wouldn't the tails still die when switching tho? I'm not sure I understand lol.
If you have a delay block the Trails parameter on and switch to a snapshot where you have that block off, the tails will still continue even though that block is off. How long they continue depends on how you have the Feedback parameter set.
