moonpup1 Posted September 24, 2021 Share Posted September 24, 2021 Was wondering if anyone’s attempted this signal chain in hx stomp: guitar->left input->left output->amp input->hx return right->hx send->pedal->right input->right output->amp return plan is to insert hx fx in 3 possible locations, and allow variable external pedal and amp preamp placement in my chain. understand I would need to do some fancy fx routing in the hx edit to allow this. Quote Link to comment Share on other sites More sharing options...
codamedia Posted September 24, 2021 Share Posted September 24, 2021 Guitar Input > HX Send L > Amp input > Amp send > HX Return L > HX Send R > Pedal > HX Return R > HX Output > Amp Return You could likely use a combo of input/outputs, but get that wrong and a feedback loop will rip your ears off ... it's a dangerous route to go. The method above keeps the signal in a flow that will not loop back on itself... unless you get the cabling wrong. Quote Link to comment Share on other sites More sharing options...
moonpup1 Posted September 24, 2021 Author Share Posted September 24, 2021 The stomp only has one fx send, I’ve seen people y split this, would this achieve the same goal? Quote Link to comment Share on other sites More sharing options...
codamedia Posted September 25, 2021 Share Posted September 25, 2021 21 hours ago, moonpup1 said: The stomp only has one fx send, I’ve seen people y split this, would this achieve the same goal? The Stomp has two sends... a TRS Cable is required to use both. TRS on one side (for the Stomp) and 2 separate 1/4" plugs on the other side. Once you get it figured out, label the 1/4" plugs so you know which one is SEND L and SEND R. This is what one of those cables looks like.... you can get them in any length, and often they are referred to as "insert cables". 1 Quote Link to comment Share on other sites More sharing options...
