jimmyp92 Posted September 26, 2021 Share Posted September 26, 2021 Hey everybody, My HD500 still won't connect to my Macbook Air 2020. When I go to System Report I continue to see VCN535JA6Y - com.line6.driver.xtaudio: Version: 7.6.8 Reason: No User Consent Date Disabled: Unknown I've tried: And I've also tried How to fix the software disabled by system: Uninstall the drivers" Take a screenshot of the disabled software to have the ID (in my case) and sent it to my phone. 3. Reboot to recovery, holding down command-r while restarting. From menu -> Utilities open terminal and type the following (replacing the system ID with yours) “spctl kext-consent disable” “spctl kext-consent add VCN535JA6Y" (replace the VCN535JA6Y with your if different) “spctl kext-consent enable" Reinstall the driver. Open system preferences -> Line6 Audio-Midi devices and plug the device into the Mac. Should appear in couple seconds. Still no luck. Is anybody having the same issue? Any solution? Thanks. Quote Link to comment Share on other sites More sharing options...
musicplayer Posted November 12, 2021 Share Posted November 12, 2021 I have the same issue. Quote Link to comment Share on other sites More sharing options...
dimakey Posted January 6, 2022 Share Posted January 6, 2022 #metoo (Macbook Pro with M1 pro) Quote Link to comment Share on other sites More sharing options...
danceboogie Posted May 30, 2022 Share Posted May 30, 2022 Yes, I've just done all this and no joy. I went through the spctl process and went into the system information and disabled software and still see the line6.driver.xtaudio showing under that area before re-installing the drivers. So, the process must not have worked. I reinstalled the drivers anyway, just in case and that didn't work. So, uninstalled, redo the process to no avail. Anyone else find success? Quote Link to comment Share on other sites More sharing options...
jakeman19 Posted June 20, 2022 Share Posted June 20, 2022 On 5/30/2022 at 4:43 PM, danceboogie said: Yes, I've just done all this and no joy. I went through the spctl process and went into the system information and disabled software and still see the line6.driver.xtaudio showing under that area before re-installing the drivers. So, the process must not have worked. I reinstalled the drivers anyway, just in case and that didn't work. So, uninstalled, redo the process to no avail. Anyone else find success? MacOS is the issue. You need to use an older version of OS. That’s why I kept my old MacBook Pro with High Sierra v10.13. With Line 6 support of older products and newer software it was inevitable. Jd Quote Link to comment Share on other sites More sharing options...
