scottlbowen Posted October 5, 2021 Share Posted October 5, 2021 Hi all, First off please let me apologize if this has been covered in another post. I have searched for a couple of days with no luck. I have an older EVH 5150 III 50. I have setup a separate preset for both that auto switches channel using Midi. Both the green channel and the Blue channel share a single volume and gain knob. When switching to the blue channel, it is WAY louder than the green channel. I do not have a foot pedal for volume control and I'm hoping I can set up a preset for each channel with volume controls for each to even them out when switching. Any ideas/solutions please? Thanks a ton in advance! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 5, 2021 Share Posted October 5, 2021 I don't have HXFX, I have HXS and Floor, thus the following questions: You're using separate presets for each channel? How are you wired? If 4cm with the FX Loop, can you use the Return Level? Mixer Block Output? Gain Block? If using IN/OUT, is there a level control on the Output? Quote Link to comment Share on other sites More sharing options...
scottlbowen Posted October 5, 2021 Author Share Posted October 5, 2021 Sorry, I am using 4CM with the FX loop and yes, separate presets for each channel I don't see away to change Mixer Block or Gain block and I have not seen a level control on the output. I'm new to all of this so I may be overlooking obvious things. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted October 5, 2021 Share Posted October 5, 2021 Page 26 of the manual (rev C) - FX Loop Settings: Page Knob Parameter Description 1 Send Adjusts the level sent to your external device. 2 Return Adjusts the level received at the Return jack. Use the Return level to adjust the level being returned from the amp's preamp section (green/blue). You can also do this in a single preset by assigning that level to Snaphot control, and using a Command Center Instant Command to send the MIDI message for the Channel change on the amp. 1 Quote Link to comment Share on other sites More sharing options...
scottlbowen Posted October 6, 2021 Author Share Posted October 6, 2021 Thanks @rd2rk! I had an older copy of the manual but to be honest, I really didn't know what I was looking for ;) Works like a charm! Quote Link to comment Share on other sites More sharing options...
