skryptus Posted October 13, 2021 Share Posted October 13, 2021 Hi guys, Is there any way of using the Aux (or equivalent) and the AUX at the same time? I use a Looper Boss RC-1) in the FX loop for some looping fun, but every now and then I also like to connect my smartphone over the AUX, which as you know, shares the same input as the FX return. As the Boss RC-1 is reported not to handle line level well, going out the main out isn't a good idea. The problem is every time I want to switch, I need to plug and unplug the cables and change the global settings so the FX return works one way or the other. I was thinking if there was some way I might have both on at the same time, so I can reduce the hassle at switching time. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
spaceatl Posted October 13, 2021 Share Posted October 13, 2021 Get a little stereo mixer and put it on the aux...If you don't want a mixer, then you could make some passive summers with some Y cables and 10k resistors... Quote Link to comment Share on other sites More sharing options...
