Dual amp with Powercab and Stomp XL
adagosto
Hi all,
This is what I'd like to do....tell me if I can and how to do it.
I have a Mesa Boogie and I'd like to send the "front of amp tones" (Wah, compressor, EQ, distortion) to the Mesa and the modulation, delay and reverb to the Mesa effects loop. So right now we're talking straight up 4CM.
Ok next, I'd like to send a different amp tone (amp model) to the Powercab along with the other tones like distortion, modulation, delay....
Can the Stomp do that?
To further complicate things, I'd also like to plug a second guitar into the Stomp or use my dual outputs on my guitar (humbuckers/peizo).
Can that be done?
How would everything get hooked up?
Thanks!
  • 3 weeks later...
4cm uses 1 input, 1 send, 1 return, 1 output
a parallel amp to powercab uses 1 output or 1 send
a second guitar or a guitar with a piezo uses 1 additional input.
stomp xl has 2 in, 2 sends, 2 returns, 2 outputs so I guess you can do it as far as hardware goes.
You need to figure out the best routing for your needs, though.
  • 1 month later...
