hetrickaj Posted November 20, 2021 Share Posted November 20, 2021 Having issues with my pod Xt not outputting any signal. i have signal going into it (able to tune) but no output from the left or right output jacks as well as the headphone Jack. double checked the PSU on my Xt live and it works just fine and is able to provide output. i have reflashed it as well as tried different cables. any other suggestions before I pop this thing open and dance around inside? Quote Link to comment Share on other sites More sharing options...
daveny5 Posted November 20, 2021 Share Posted November 20, 2021 Try recalibrating the foot pedal. Q: How do I calibrate the pedal on my PODxt Live? A: 1. Make sure there is nothing connected to your PODxt live aside from the power cable. 2. Power up the PODxt Live while holding down the Bank Up pedal 3. Press the Amp pedal (this will reset the current settings) 4. Move the pedal all the way to the heel back position, then all the way forward until the toe switch clicks. You will want to stand up and shift all of your weight to the toe position until you see the WAH light turn on. 5. Wait 10 seconds, then power the PODxt Live off and back on again. 6. Your pedal is now calibrated. Quote Link to comment Share on other sites More sharing options...
hetrickaj Posted November 20, 2021 Author Share Posted November 20, 2021 Thanks for these troubleshooting steps, but these are for the Xt live pedal, I have the Pod XT Quote Link to comment Share on other sites More sharing options...
daveny5 Posted November 20, 2021 Share Posted November 20, 2021 Sorry about that. I don't know what else to suggest. Do you have the original power supply? Did you try running Line6 Edit or Gearbox to see if that gets anything? Quote Link to comment Share on other sites More sharing options...
hetrickaj Posted November 24, 2021 Author Share Posted November 24, 2021 On 11/20/2021 at 1:23 PM, daveny5 said: Sorry about that. I don't know what else to suggest. Do you have the original power supply? Did you try running Line6 Edit or Gearbox to see if that gets anything? yeah, I have the original power supply powering it i think it may have something to do with the chip on board, if it's gone bonkers then im not gonna get any output out of it. does anyone else have any extra steps i can try? one note i see too is the power caps are kind of swollen which i will be replacing for sure. Thanks! Quote Link to comment Share on other sites More sharing options...
