HD0212 Posted November 23, 2021 Share Posted November 23, 2021 I got a Helix lt and after not connecting it to the pc after a while i noticed that the hx edit and the updater does not recognize it, i tried restarting the usb ports along with many other things. ( both programs are up to date) and nothing gives. In the device manager it gives me something like msg pipe, and i tried everything under the sun to troubleshoot it and nothing. Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 23, 2021 Share Posted November 23, 2021 That little exclamation point icon beside the Helix in the Device Manager indicates that the drivers are missing. Try re-installing HX Edit to see if you can get the drivers to install again. Quote Link to comment Share on other sites More sharing options...
HD0212 Posted November 24, 2021 Author Share Posted November 24, 2021 I've done that multiple times even installing the drivers separately and nothing Quote Link to comment Share on other sites More sharing options...
Maddaxe Posted November 24, 2021 Share Posted November 24, 2021 I'm having the exact same issue. Any help would be appreciated. Is there a factory reset? 1 Quote Link to comment Share on other sites More sharing options...
HD0212 Posted November 24, 2021 Author Share Posted November 24, 2021 factory reset on the helix won't do anything i just did that and now i have locked myself out of all my presets lol Quote Link to comment Share on other sites More sharing options...
Anderton Posted November 24, 2021 Share Posted November 24, 2021 The USB port and cable matter. If you're using a USB hub, that could be a problem. I recommend plugging anything audio directly into a motherboard's USB connector, preferably one close to the power supply. Also, some USB cables carry only power (e.g., for charging phones), not data. Make sure your cable is actually carrying data. Finally, remember that Helix needs to be not connected when you install the driver. Try uninstalling the driver, unplug Helix, reboot, install the driver, reboot, and then plug in Helix. This might help...good luck. 2 Quote Link to comment Share on other sites More sharing options...
