POD Go, two more presets with momentary switches?
InacticeTrash
The momentary switches can do anything functionality wise that the main 6 switches can do, but currently these are not visible in the Pod Go display. You cannot view more presets in the window because that's to do with Pod Go architecture, not the footswitches.  However since v1.30 you can go into stomp mode to see all 6 blocks and set FS7/8 to scroll through patches which you couldn't do previously.
A great advantage of FS7/8 for live gigging is that if you set these to kick in eg a distortion or volume boost e.g. for a solo, these operate regardless of what mode you're in. In other words these can act as an independent control pedal without you having to go from preset mode and then to stomp mode and back again.
  • Thanks 1
