HxSTOMP multi-bypass MIDI assign to toggle 2 blocks?
DgfxDgfx
Hi, I've set up my HX stomp with multi-bypass assignment to toggle 2 blocks, using one of the FOOTSWITCHES, is it possible to do this using a MIDI footswitch ?
(from a MELOaudio MIDI unit). I tried to set up with the Melomidi but it seems it will only BYPASS / TURN ON the 2 blocks at the same time, ie. not with the opposite Bypass state.
Thanks for any help.
Not familiar with the capabilities of Melo, but if the FS can send 2 toggling CCs on a single press, assign each block a separate CC# (ex - 111 and 112) and set them so that on first press:
CC#111 Value 127 (ON)
CC#112 Value 0 (OFF)
second press sends the reverse:
CC#111 Value 0 (OFF)
CC#112 Value 127 (ON)
FCB1010/UNO can do this, but the stock FCB chip can't, nor can Helix. It really depends upon what the Melo is capable of. Time to RTM!
If you're talking about the Midi Commander, I looked at the v1.0 manual and it doesn't look like it will work, as each button can send only one message at a time.
