Does Powercab usb interface record both inputs?
abteenz
I'm trying to record what is coming out of the power cab from both inputs. My backing track is going through input 2 with flat settings and my guitar tone to input one with some cab settings.
I can't seem to be abale to capture the backing track when trying to record with power cab usb interface. Any ideas?
Thanks.
  • 2 months later...
In a similar vein, I want to use the PC USB interface to record the iridium in stereo into Garage Band/other DAWs
If I send the iridiums stereo outs to both PC inputs, will the USB interface pick up both L/R inputs for recording? The manual instructs you to plug into input2..
Thank you!
In Global Settings, set Input 2 to NORMAL.
Set Link Inputs ON unless you want to set input levels separately.
Left input is routed to Left output.
Right input is routed to Right output.
Signals are processed. IOW - Speaker Sims and User IRs stored on Powercab can be applied, in stereo.
