VmusicV Posted February 21, 2022 Share Posted February 21, 2022 Hi, I have a preset with 2, what I'm hoping is ..... independent signal chains. The top chain is strictly for guitar fx. The Snapshots are used to control the settings in the various Fx blocks - but ONLY in this top signal chain The Snapshots do not control ANYTHING in the lower/2nd signal chain The bottom chain is strictly for synth /string pad - which turns on/off with the 3 note generator (then it goes to a 3 note Synth Oscillator and to a 2 note Pitch Shifter) The starting Fx block, the 3 note generator is turned on/off via a Stomp Footswitch... which IS NOT used for anything else The problem: I go to the preset, Snapshot 1, then I start the synth.... it's playing..... then I switch to Snapshot 2 or 4 or 5, to play on top of the synth pad; then the synth STOPS playing. I walked through the snapshots, one by one, and didn't see that the 3 note generator is impacted or controlled in any way to any of the snapshots. But as soon as I change snapshots, the synth pad stops playing. Any Thoughts WhatzWrongSynth.hlx Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 22, 2022 Share Posted February 22, 2022 In your Snapshots it's saved OFF. If you switch to a Snapshot where it's OFF it stops. In the 3-note Generator Block, uncheck "Snapshot Bypass". In Global Settings>Preferences set Snapshot Edits to Discard. Now it stays ON unless you turn it OFF. 1 Quote Link to comment Share on other sites More sharing options...
VmusicV Posted February 23, 2022 Author Share Posted February 23, 2022 @rd2rk THANK YOU!!! Quote Link to comment Share on other sites More sharing options...
