zgranger Posted March 3, 2022 Share Posted March 3, 2022 Hey guys ever since I updated my tap tempo is set to external and the led is blue. I use the boss ms3 for some midi stuff but I'm not sure how to change it back. When I go to global settings it wont let me change it back. Thanks anything helps! Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 3, 2022 Share Posted March 3, 2022 7 hours ago, zgranger said: Hey guys ever since I updated my tap tempo is set to external and the led is blue. I use the boss ms3 for some midi stuff but I'm not sure how to change it back. When I go to global settings it wont let me change it back. Thanks anything helps! Hi, After performing the Firmware update, did you do a factory reset, and restore from backup, as per the update installation notes? When you updated the Firmware, your previous Global settings will have been erased - that is the purpose of the restore routine. This should put them back to how you had them set before the update, and avoids situations like this. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
