what did i do? how do i fix it?
robhsm
7 hours ago, robhsm said:
I did an update and now everything I do results in this error:
Can you be more specific? ‘Everything’ is a bit broad. What exactly are you doing when this error is generated? Does the Edit program open at all, or does this error occur immediately upon opening? What happens if you hit the OK button?
My first guess is that your version of Pod GO Edit is different from the installed firmware version. Check your versions using the ‘About…’ feature in Pod GO Edit. If the versions are the same we need more details to help you.
