Auto Swell in Reverse - Auto Quiet?
VmusicV
   Is there a way to configure or setup the Autoswell in reverse?  So..... over some time period it gets quieter and quieter?
I'm not certain what the 'RelOffset' (relative offset) is, if that can make the AutoSwell go one way or another.
Not So Swell in Seattle
Don't tell me............... isn't that what compression is?
HhhhHHHhhmmmm...... I suppose it is - it's not exactly time based, but it's typically threshold based. When the volume level gets above a certain threshold.... it kicks in.
Hey, VMusicV -- Ever heard of a noise gate?  The noise gate's purpose is to prevent low signal aka noise from being heard.  So if you tweak the settings, you can get the "auto fade out" effect.
Put this at the end of your chain, after the amp, etc.
Play with the parameters.  You probably want to bypass it and un-bypass it repeatedly to make sure it does not affect the loudness of your signal.
Threshold: how sensitive you want the noise gate to be.
Decay: how soon you want the note to die out.
Level: this is so that the noise gate does not affect your overall loudness.
These are the settings that achieved the effect for me.
Cool?
958230267_ScreenShot2022-03-04at2_00_11PM.thumb.png.9d2ec5b573589b72bf147485fb94deaf.png
